Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unique cooling problem??
Old 04-07-2010, 12:37 AM
Scrumgees Scrumgees is offline
i could try that water wetter, the idea of reduced surface tension makes for good sense, as well as slowing down the pump but i, gonna try this larger bore thermostat first. Start cheap and work toward a solution, cause if reducing backpressure is the key, thats a $15 fix
