Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unique cooling problem??
Old 04-25-2010, 04:13 PM
Scrumgees Scrumgees is offline
Problem fixed
Well I have routed the bypass and put in the Mr. Gaskety thermostat and it cools the engine much more consistently with the bypass than it ever did even with the old pump. The engine just climbs to 185 and and stays there. So the problem was cavitation because there was not sufficient return flow to the pump to provide circulation which the bypass solved. Probally could have benifited to old pump too
Thanks oldbogie and everyone else. worked out great!
ID:	45349   Click image for larger version
ID:	45350   Click image for larger version
ID:	45351   Click image for larger version
