Unisteer Cross Steer Rack and Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2004, 11:55 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
Thumbs up Unisteer Cross Steer Rack and Pinion
Hey all I just finsihed installing the New Unisteer Cross steer unit on my 1925 Chevy sedan. the unit allows you to install manual rack and pinion on a classic tube or Ibeam axle. It seems to work out great! It was a bolt in replacement for my Vega box and allowed enough clearance for hedders now, before there was no chance. Has anyone else used this set up? So far I am very impressed with the company and their support.
www.unisteer.com/CrossSteer.html
Old 02-25-2004, 10:59 AM
Markmc59's Avatar
New Member
Friscoe, I wanted to say thank you for the extra effort, was not able to pursue at the time, had bout due to knee surgery, you saved me a lot of time and helped me find a solution, thanks again for extra effort.
I will let you know how my new Unisteer system works out when I get it installed.
Old 09-03-2004, 02:30 PM
32Hoopie's Avatar
Still like the Cross Steer unit?
I see by the post date that you've had the Cross Steer unit for a little while now, and do you still like it? I have 32 Ford that currently has a worn out Vega box and would like to replace it with the Cross Steer unit from Maval. Go or No go? Love the pictures of your ride... Thanks
Old 09-03-2004, 02:50 PM
Not A T 25's Avatar
Re: Still like the Cross Steer unit?
I am very satisfied! the steering response is wonderful compared to the Vega box. I would recommend the unit as far as my experience goes. If you have any specific questions please let me know.
Mark
Old 09-03-2004, 04:15 PM
32Hoopie's Avatar
Great to hear your experience has been positive. Did you have to install any extensions for the steering rods? Or did you simply replace the Vega unit. It looks like the steering hook-up is not exactly in the same place, maybe a little more forward than the old Vega connection.
Old 09-03-2004, 04:22 PM
aka Duke of URL
Thumbs up
WHAT A GREAT PRODUCT!
Mark,
Does the unit appear heavy enough to steer a mid-fifties FORD with a heavy engine on an ECONOLINE axle? Have you heard anything about a power assist?
Old 09-05-2004, 09:16 AM
Not A T 25's Avatar
The unit does sit forward of the Vega box location which gives much more header clearance but all linkage is in the same location no additional changes were required. I did have to make an adapter bracket for my 1925 chevy to drop the unit but they have since taken my design and produced an appropriate bracket for my car. As far as your car it should be a direct fit with no modifications necessary. My car is pretty light with a SBC and I don't need any power assist it steers very easy much nicer than the old vega box. I don't know of any power assist for the cross Steer unit but they are very helpful and an Email to them should get a quick response. This unit gave me all kinds of clearance for headers which I could not fit before. I think I have some pictures of my install in my gallery if not I will post a couple. Hope this helps good luck!
Old 09-07-2004, 08:55 AM
32Hoopie's Avatar
Thanks for the input. I took a look at the pictures and I think we're a go! I'll let you know how my installation goes. C ya...
Old 09-28-2004, 03:37 PM
32Hoopie's Avatar
Thumbs up Yahoo...
Just a follow-up note. The Maval Cross-steer replacement unit for my old Vega box went great. After a little adjusting to get the steering wheel straight, I'm good to go... No more 3" slop, tracks great, very responsive and smooth. You can add me to the list of very satisfied customers. My only complaint is that I waited to long to install it! Thanks again for the encouragement. Keep on Roddin'
Ken
Old 09-28-2004, 06:06 PM
Ihave a 1941 Mercury. I emailed them to see if the unit would work on my car. I also stated that I was sure I would have to make a bracket to mount unit to the frame since the Merc frame is different than Ford. I waited 10 days for reply and this is what I got, ("No,Sorry") Kind of thought I would get a little more help as to why not or whatever.
Old 09-28-2004, 06:19 PM
Not A T 25's Avatar
I am sorry to hear that I didnt get lightning fast response either and did have to send some follow up Emails, Malval is a big company they make many OEM rack and pinion systems if you are really interested you might try going up the ladder!
