-   -   Unisteer installation on 32 Ford (http://www.hotrodders.com/forum/unisteer-installation-32-ford-100833.html)
OU812 10-22-2006 12:10 PM
I have a 32 ford 3 window that I am installing a Marval Unisteer into. Does anyone have pictures of resent installs they have done. Is the Unisteer to be mounted parallel with the tie rod? If so, then the unit hang very low. If you mount in the location of the vega box, then the unit is at angle. Anyone have any pictures or better instructions than provided by the manufacturer. Thanks for any help.
Deuce 10-22-2006 03:50 PM
:welcome: WELCOME to Hotrodders.com :welcome:
As a Moderator here and a fellow 32 Ford owner, I want to be the first to WELCOME you here ... :D
http://hotrodders.com/journal_photos...1456602170.jpg
http://hotrodders.com/journal_photos...1431451842.jpg
Above are the photos of the UniSteer installed on my 1932 Ford 3W coupe. :) Click on the link below to see more construction photos of the 3W project ...
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Again WELCOME ...
Deuce ... Moderator
heyjude076 10-23-2006 05:44 AM
Hi Duece
Thanks for the reply to my earlier question. Guess I am also going to go this route. Something I did not pick up on when I first saw these pics - no panhard bar? Is that because of Unisteer, 4 bar link or a combination of both?
Deuce 10-23-2006 07:48 AM
Originally Posted by heyjude076
Hi Deuce
I have a panhard bar ... it is just not installed in the photo ...
LOOK on the left side of the chassis ... just below the frame rail ... at the front crossmember and you can see the bracket hanging down a little. I used a TCI panhard bar setup. In fact ... all the front suspension came from TCI. I used the original 32 Ford frame rails from under my 32 3W ... ( complete with the matching numbers to the title ) but then added the TCI " phase III " show setup.
OU812 10-23-2006 08:49 PM
Deuce, thanks for the reply and pictures.
Deuce 10-23-2006 11:17 PM
You are most WELCOME ... :welcome:
Hotrodders.com is one of the most friendly and informative places on the web ...
Deuce ...
home brew 10-23-2006 11:58 PM
And Deuce is one of the most friendly and informative members on the site. Do you have a close up of how the unit is attached to the frame?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
pasadenahotrod 10-24-2006 11:50 AM
Parallel to the tierod not parallel to the ground.
The bracket should place the steering unit with the tie rod parallel to the tie rod but not necessarily in the same plane as the tie rod.
32deuce51 09-30-2012 09:06 PM
Unisteer
Hi Deuce, I'm the newbie!!! Thanks for the welcome. I'm doing over my 32 5w. I see the pics of the Unisteer setup on yours. You say you have a vega box in your other 32. I'm considering going that route. Putting in a 351 windsor and it's pretty tight and busy with the vega box with oil filter, fuel pump, and rad hose all in that area. Looks like I'd have more room with Unisteer. Which do you like better? Thanks, Lou By the way beautiful cars!!
Deuce 10-02-2012 08:54 AM
I answered your PM ...
Sorry for the delay BUT I was out of town for a week. The wife and I went to The Rodders Journal event in Baltimore MD. For a first show ... it was KILLER. Great location, well organized and LOTS of 32 Fords.
My 3W @ Baltimore :D
http://i1203.photobucket.com/albums/...w/100_6570.jpg
There was a very high percentage of 32 Fords there
http://farm9.staticflickr.com/8453/8...f860d46e_b.jpg
