Unisteer installation on 32 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2006, 11:10 AM
I have a 32 ford 3 window that I am installing a Marval Unisteer into. Does anyone have pictures of resent installs they have done. Is the Unisteer to be mounted parallel with the tie rod? If so, then the unit hang very low. If you mount in the location of the vega box, then the unit is at angle. Anyone have any pictures or better instructions than provided by the manufacturer. Thanks for any help.
Old 10-22-2006, 02:50 PM
WELCOME to Hotrodders.com
As a Moderator here and a fellow 32 Ford owner, I want to be the first to WELCOME you here ...
Above are the photos of the UniSteer installed on my 1932 Ford 3W coupe. Click on the link below to see more construction photos of the 3W project ...
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Again WELCOME ...
Deuce ... Moderator
Old 10-23-2006, 04:44 AM
Last journal entry: Bringing home the 401 Nailhead
Hi Duece
Thanks for the reply to my earlier question. Guess I am also going to go this route. Something I did not pick up on when I first saw these pics - no panhard bar? Is that because of Unisteer, 4 bar link or a combination of both?
Old 10-23-2006, 06:48 AM
Originally Posted by heyjude076
Hi Deuce
I have a panhard bar ... it is just not installed in the photo ...
LOOK on the left side of the chassis ... just below the frame rail ... at the front crossmember and you can see the bracket hanging down a little. I used a TCI panhard bar setup. In fact ... all the front suspension came from TCI. I used the original 32 Ford frame rails from under my 32 3W ... ( complete with the matching numbers to the title ) but then added the TCI " phase III " show setup.
Old 10-23-2006, 07:49 PM
Deuce, thanks for the reply and pictures.
Old 10-23-2006, 10:17 PM
You are most WELCOME ...
Hotrodders.com is one of the most friendly and informative places on the web ...
Deuce ...
Old 10-23-2006, 10:58 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
And Deuce is one of the most friendly and informative members on the site. Do you have a close up of how the unit is attached to the frame?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 10-24-2006, 10:50 AM
Parallel to the tierod not parallel to the ground.
The bracket should place the steering unit with the tie rod parallel to the tie rod but not necessarily in the same plane as the tie rod.
Old 09-30-2012, 08:06 PM
Unisteer
Hi Deuce, I'm the newbie!!! Thanks for the welcome. I'm doing over my 32 5w. I see the pics of the Unisteer setup on yours. You say you have a vega box in your other 32. I'm considering going that route. Putting in a 351 windsor and it's pretty tight and busy with the vega box with oil filter, fuel pump, and rad hose all in that area. Looks like I'd have more room with Unisteer. Which do you like better? Thanks, Lou By the way beautiful cars!!
Old 10-02-2012, 07:54 AM
I answered your PM ...
Sorry for the delay BUT I was out of town for a week. The wife and I went to The Rodders Journal event in Baltimore MD. For a first show ... it was KILLER. Great location, well organized and LOTS of 32 Fords.
My 3W @ Baltimore
There was a very high percentage of 32 Fords there
'32 ford question bonuts Body - Exterior 9 02-18-2009 03:23 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
32 ford sedan w/underfloor master cylinder heyjude076 Suspension - Brakes - Steering 2 08-31-2006 09:28 AM
'32 Ford Truck Windshield Wiper Systems rcrfly General Rodding Tech 2 08-12-2006 08:50 AM
Indepenece for a 32 ford scottvnz Suspension - Brakes - Steering 4 12-12-2005 12:11 AM
