Unisteer S/S u-joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2011, 01:45 AM
327NUT's Avatar
I did a search and read some replys on these parts, they seem like they are pretty nice but I can't find out if they are forged or investment cast. Also, depending on who's selling them some say the Unisteer pinch bolt type is best and the Borgeson dealers say the set screw type is best. Anyone have any REAL experience or failures with either?
Old 02-10-2011, 06:59 AM
da34guy's Avatar
Dave --- Just my 2 cents, but I've always used the set screw type, more of a positive lock with a drill set for the bolt to bite.
Old 02-10-2011, 10:58 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Same here the screw in type is the one I prefer, just seems like a better design.
The unisteer will accept the screw in type without modification if that is the concern. No drilling for the set screw, it has enough room on the spline that the U joint will slip down and allow the set screw to use the grove.
Old 02-10-2011, 11:35 AM
302 Z28's Avatar
I prefer the steering u-joints from Borgeson and Flaming River both of which use the set screw. Quality steering U-joints are expensive and this is one area where you get what you pay for, kinda like brakes.
Vince
Old 02-11-2011, 12:43 AM
327NUT's Avatar
Ok, thanks guys....Don, I thought you used the u joints from Sweet? Another question, do any of you use a vibration damper/u-joint at the column? This is going to be connected to an Omni r&p 3/4 DD x9/16X26. My understanding that a manual r&p didn't really need one, only if you were using a power rack. Never had one so dunno.
Old 02-11-2011, 05:43 AM
da34guy's Avatar
Dave, I use both Sweet and Borgenson(dealer for both)
as to vib dampner.
Never used 1 on a R&P
Don't need it !
Unisteer installation on 32 Ford OU812 Suspension - Brakes - Steering 9 10-02-2012 08:54 AM
Seating Unisteer u joints on rack and pinion 001mustang Suspension - Brakes - Steering 4 08-29-2010 11:38 AM
Unisteer Quetion Ted's37 Suspension - Brakes - Steering 8 05-15-2009 05:42 AM
Unisteer stringbean Suspension - Brakes - Steering 3 05-12-2009 11:02 AM
Unisteer stringbean Suspension - Brakes - Steering 28 12-19-2007 05:10 PM
