Universal brake switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2010, 05:33 PM
Last journal entry: comming along
I have one of those universal brake light switches. For the life of me.. I can't figure out how to install the little guy. The only thing I can think of is to use some long machine screws. Then go threw the floor with the screws and kind of have the switch float down there. It has to push down on the arm. My pedal doesn't go down all that far, so I figure there has to be pressure on the arm at all times.. Al
Old 05-17-2010, 09:30 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
The switch when it is in the relaxed position will activate the brake lights. When pressure is applied to the arm the switch will go into the open position, no contact in the circuit will take place and brake light will not light.
To check out this operation, attach voltage multi-meter to the two contacts in the ohm's with alarm position. If meter sounds it is in the N.C. (normally closed position), if it doesn't sound it is in the N.O. (normally open position). Try it!
brake pressure switch kwopper07 Suspension - Brakes - Steering 3 06-11-2009 12:15 PM
Under Dash universal brake systems Javelin69 Suspension - Brakes - Steering 0 07-29-2008 06:03 PM
Brake light switch? cabrio Electrical 14 05-04-2007 06:08 PM
brake light pressure switch plymouth_man Suspension - Brakes - Steering 2 04-25-2007 05:47 PM
mechanical brake light switch colobronco Electrical 2 08-18-2004 05:54 PM
