universal horn hookup?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 12:24 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
Putting new Fiam universal horn in 98 windstar.
Has a 1 n 2 hookup option. I got a pushbutton horn button to. What wires go were? Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-28-2007, 01:15 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Can describe the connection options in more detail?
vicrod
Old 01-28-2007, 02:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
In most STOCK type connections, The Horn will connect as Follows:
  • One Side of the Horn button to ground.
  • The other side to the horn relay COIL (Contact #86 )ground.
  • Horn relay COIL ( Contact #85 ) Positive to A "Hot At All Times" 12 volt FUSED (1 amp) Source.
  • The Normally OPEN Contact ( Contact #87 ), to a Fused 12 volt hot at all times source (the battery).
  • The CENTER WIPER, (Contact #30) To The Horn power.
When the Button is pressed, it provides GROUND to the relay coil, which is wired "Hot At all Times" and activates the relay.
The Contacts Numbers 87 and 30 close and provide power from the battery to the horn , and when released, open the circuit.
Hope it helps!
Doc
Old 10-22-2011, 09:44 PM
Horn hookup
Doc, I read your post on how to wire a horn relay and how it works. Very informative. I have a 36 Ford pickup with an Ididit column and a Grant steering wheel with two connection terminals on the horn button. I finally got around to buying a two wire horn for it but can't get it to work. I am attaching the wheel installation instructions (for wiring) and the relay wiring diagram that I used. Since your post is so old I tried to send you a private message but couldn't figure out how to do attachments. The instructions from Grant are telling me not to use the ground terminal on the horn button. I am attaching the instructions from Grant and the relay wiring diagram that I used. Hopefully you will see this and tell me where I am going wrong. Thank you.
Name:	IMG_1776 (Small).JPG
ID:	59106   Click image for larger version
Name:	IMG_1778 (Small).JPG
Old 10-23-2011, 04:07 AM
jon72vega's Avatar
WOW, I could have had a V8!
Rustman,
docvette passed away several years ago.
Jon
http://1972vega.wordpress.com/
Old 10-23-2011, 11:10 AM
Sorry to hear that. Thanks for the update.
Old 10-24-2011, 02:57 PM
vicrod's Avatar
life is a ride
The horn control as described by DOC is a single wire system. Single wire means that a single wire goes to the horn button. When the button is pressed a circuit is completed to ground through the steering column. This circuit to ground energizes the coil of the relay (terminal #86).
The relay then closes and provides power to the horns. (terminals #30,#87)
The sketch you attached is a 2 wire system that requires + power to the horn button and a second wire from the horn button to the relay.
The Grant instructions allow either option but it depends on the wiring of the steering column.
vicrod
Old 10-29-2011, 09:20 AM
horn hookup
Vicrod, please let me know if you think I have this right. Connect a ground wire from the horn button ground terminal to a ground on the steering wheel mounting piece. Connect the black wire coming from the column to the center terminal on the horn button. Connect the other end of the black wire from the column to # 86 on the horn relay. Connect wire from #85 to access. side of ignition switch. Connect wire from #87 to battery + terminal. Connect wire from #30 to one of the two terminals on the horn. I am assuming the the other terminal on the horn would be grounded.
The reason for making and hooking up the ground wire between the horn button terminal and the wheel mounting piece is because I misunderstood Grants instructions and cut the part of the horn spring that would have provided the ground. Any suggestion on wire sizes? Thank very much for your help.
Old 10-29-2011, 03:06 PM
EOD Guy's Avatar
I'd wire it like this. Using the horn button to complete the ground to the relay..... no pwr running up the column, so no sparks if it ever shorts out.
Old 10-30-2011, 05:30 PM
vicrod's Avatar
life is a ride
In the horn button, somehow, when the horn button is pressed a circuit is completed to ground. I don't know your exact setup but some kind of brush and ring arrangement is common.
Terminal #85 is usually hot at all times thus allowing the horn to be used regardless of the ignition position. See EOD guy diagram.
#14 wire should be adequate for the horns.
Don't forget the fuse. 20 amp max for #14 wire.
vicrod
What's needed to wire a horn at the steering wheel? jpd37 Electrical 9 06-22-2009 07:53 AM
Replace existing horn w/ ooga horn? BobbyG-39 Electrical 14 11-03-2007 01:58 PM
problems with the horn not working solamisandwich Electrical 4 12-24-2006 02:00 AM
64 Impala Horn Problem dmaggard Electrical 28 09-14-2006 12:01 AM
69 GM Column Horn Problems Campbem Electrical 7 12-31-2004 11:25 PM
