universal (hurst) motor mount question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2006, 11:10 AM
Is it really taboo to use the hurst front mount with a TH350 and its own original tail mount?
It seems theres only about 4" difference compared to the side mount location.
Thanks for any and all input!
Old 12-15-2006, 11:18 AM
With side mounts, the motor is supported by the mounts. With front mounts you're asking the thin aluminum bell housing to carry the load. I see a lot of them done that way. I wouldn't recomend it.
Bob
Old 12-15-2006, 12:51 PM
T buckets rule
If you have room get a engine mid mount that goes between the engine and the trans. They are about 1/8" thick then bolt to the frame. That will support the engine. They use this set up in drag cars alot.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
