Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Universal Master Cylender
Old 08-12-2002, 10:20 AM
stevesauto's Avatar
stevesauto stevesauto is offline
Post
steve here one thing you need to do is like the other guy said ck the plunger travel the other thing you need to do is bench bleed the master cylinder need to take the brake lines off the master cyl. and put some rubber hoses from the master cyl. and put them back into the top of the resovor submerged in the fluid and then pump your pedal slow till all the air is out if you do not get any fluid out then something is wrong with your master cyl. or the push rod is to short hope this helps steve.
