Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-15-2006, 07:58 PM
49dream 49dream is offline
universal steering shaft joints
Can one get the universal joint on the steering shaft to close to the headers
The way my new rack is located and the best way to connect everything will put my universal joint 1/2 inch from my headers. I concerned about damage to any seals in the joint.
  #2
Old 03-15-2006, 08:09 PM
copndoc3's Avatar
copndoc3 copndoc3 is offline
Retired Super Trooper
Last journal entry: The Uncommon Street Rod - Photoshoot
I would venture to say that if you have 1/2" that would be sufficient. As long as there is an air gap between the headers and u-joint and air can flow freely around it, you should be good to go. Hey, consider yourself lucky that you have that much.....some designs or installations don't have that much. You could also check with the manufacturer of the u-joint and ask their recommendation.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "universal steering shaft joints"
ThreadThread StarterForumRepliesLast Post
'39 ford steering column and wheeljim williamsSuspension - Brakes - Steering507-01-2010 10:38 PM
how do I remove universal jointsNeophyteTransmission - Rearend1102-05-2005 12:36 PM
steering column shaft movesRodFatherSuspension - Brakes - Steering1101-13-2005 05:13 PM
cure for worn steering shaft?cboySuspension - Brakes - Steering204-07-2004 10:21 AM
Hotrodders Knowledge Cluster: Power Steering ConversionsJonSuspension - Brakes - Steering009-04-2003 12:20 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
