Universal turn signal install - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 06:26 PM
Just happy to be involved :)
hi all, am planning on picking up a universal turn signal switch like a signal stat, or a truck lite unit, I work at a Freightliner dealership and get a discount.
Anyways, I have a 55 Dodge 1/2 ton that I am converting to 12 volt and was wondering if I should get the 4 wire switch or the 7 wire switch, I have a EZ Wiring brand 21 circuit harness that I'll be using. If Im going to run marker lamps / running lamps as well as turn signal indicators in the lamps what do I get? The 4 wire unit info says for signal lamps only, but the 7 wire unit says nothing ....I want to plan ahead as much as I can.
Thanks!
Derek
Old 03-03-2006, 07:32 PM
turn signal
My universal has 7 wires- could it be the 4-way flasher? Bill
Old 03-04-2006, 09:26 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached sketch shows the wiring of a typical combination T.S. - hazard switch.
The 7 wires are:
Power hot or hazard flasher
Power ignition switched or T.S. flasher
From brake light switch
To left front lamp(s)
To right front lamp(s)
To left rear lamp(s)
To right rear lamp(s)
Marker lights won't be controlled by T.S. sw.
vicrod
crazy right turn signal fasteddiesage Electrical 6 02-07-2006 10:33 AM
1963 Impala Steering column, turn signal switch BADSBRD Electrical 4 10-13-2005 10:17 AM
Yankee Turnflex Turn Signal Wiring kingcaddy Electrical 4 07-14-2005 09:00 PM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
Weird Turn Signal Problem on my 63 Impala ataririder Electrical 2 03-07-2003 09:29 PM
