Small block chryslers are set up just like gm's, the big block is where the dizzy's on the front at an angle. Look at the valve cover bolt pattern, chevys are the standard 4 bolt while chrysler is 2 on top, 3 on the bottom. Also if the block # ends in 273,318,340 or 360, you got a small block chrysler.
