unknown engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2005, 11:41 AM
unknown engine
I have an engine that I have a block number that I can trace to a the year 1967 gm motor, but I am having a hard time trying to locate the model vehicle it came out of. Any leads as to where I can find information?
Old 07-09-2005, 11:51 AM
As one of the Moderators here.....let me be the first to WELCOME YOU.. here....
What type of engine is it.........Chevrolet, Buick, Olds or Caddy ?
Different members here have knowledge of different GM divisions....
IF it is a Chevrolet........there should be a code stamped on the front pad..right side above the water pump.
In the area circled.......post the entire number and letters and we can most likely help.......
DEUCE.........
Old 07-09-2005, 09:31 PM
MI2600's Avatar
Member# 3287
Chevy small blocks have ID numbers as noted:
Old 07-10-2005, 11:04 AM
Engine Numbers
I have both numbers off the block, I have E-mailed GM and have been told that the first # shows it to be a Chevy.The two numbers are as follows; front passenger side #T0112HC, the second rear drivers side #C3903352. I have been told it was a 1967, can someone can help me get more history on this motor (or information so I can research it myself)
Old 07-10-2005, 07:11 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
T=Tonawanda Engine Plant
01=Assembly Month (January)
12= Assembly Day
HC 1965 327 275 4 Powerglide
HC 1969 350 250 2 m/t
HC 1967 327 275 4 Powerglide
3903352 1967 327 210-350 2 Passenger/Chevelle/Corvette/Camaro
Old 07-11-2005, 01:27 PM
Biggarmike's Avatar
Chief Procrastinator
small journal 327, may have a steel crank too. it's a keeper. even if it's the 210/ 2bbl engine, it likely came with 1.94"/ 1.5" heads (not the infamous "humpty-humps") This is a fine little smallblock for a 60s mild to middlin street car, excellent in a Nova or shoebox Chevelle/ El Camino.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
ENGINE BALANCING NAIRB Engine 14 09-06-2011 08:22 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine rebuild ...... Help stingraymax Engine 2 11-11-2003 06:17 PM
454 engine swap joes stude Engine 1 07-17-2003 08:12 AM
