Unknown Ford 460 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 03:03 PM
Hi, I just bought a hot rod work in progress. It is a Ford 1948 F1 shortbed pickup, with a 460 cin ford engine. My probl;em is that the former owner knows next to nothing about the engine, other than it ran when he bought it. It needs a coil, as he removed the old one and lost it. So In order to try to get it running I need to start there. The intake manifold has the following stamped on it, DOAE - 9425 - F. From this I think the engine is a 1970 460 out of a galaxie, but am not sure. Can I buy any coil for this, or do I need a special one? #2 what is the proper wiring of this, and does anyone have a basic wiring schematic to check that everything is wired properly. It is converted to 12 volts. #3 What would be a good size battery for this engine with long battery cables going into the cab at thios point?
Thanks, any help would be appreciated! Steve (stovens)
Old 10-04-2007, 03:28 PM
Jmark's Avatar
Basically, any 12v external coil will work. (assuming it still has a points type distributor) Negative side of the coil goes to the dist/points. Positive side goes to a switched 12v source.
A moderate to high end group 24 top post should be fine. Checker or AZ can handle it.
You may want to get some serious welding cable if the battery run is long. But if its under the seat and only goes to the starter, you may find good cables long enough at the auto parts store.
Old 10-04-2007, 06:19 PM
JMARK
Thanks,
Got it to crank, but not start. Next will check for spark and fuel supply.
Old 10-06-2007, 09:32 AM
Juice to coil but no spark
Hi
I put in a new coil and tested the positive terminal with a volt meter grounded to the engine block, and got 12volts on the meter. Next I tested for electricity across the coil with the ingnition switch on, + terminal with red wire to + side of meter, - lead to negative side of coil, no volts. I also tried this while cranking it over, still no volts or spark. Any ideas of what could be the problem? I'm guessing it has something to do with the distributor, but lack a schematic to check the current wiring of the points and condensor. Help.
Old 10-06-2007, 10:21 AM
aka Duke of URL
Do you have BATT VOLT at the hot side of the coil while cranking? Depending on year of donor vehicle, cranking VOLT came from either the IGN SW or STARTER SOLENOID. If you are sure the point gap is correct and the grounds are correct, connect a temporary jumper from BAT VOLT to the + side of the coil while cranking. A bad condensor will also ground the system.
ID:	24697   Click image for larger version
Name:	Points Type Distributor_2.jpg
ID:	24698   Click image for larger version
Name:	Mechanical Points Schematic.jpg
Old 10-06-2007, 01:39 PM
Starting 460
I put a new condensor in the ignition, checked to see if old points are opening and closing - they are, still no juice out of the coil wire or to the plugs. Thanks for the diagram, I'll try cleaning the ground wire next.
Old 10-06-2007, 02:22 PM
aka Duke of URL
With the key on, open the points set with a screwdriver and see if there is a spark.
The black wire (-) from the coil to the points is a ground only. There is also a non-insulated wire that grounds the upper breaker plate to the distributor housing (via the lower breaker plate).
Ford Anglia / 460 Ford Help martin UK Introduce Yourself 1 12-19-2006 01:19 PM
Need some info on 460 Ford....... onebadmerc Engine 2 11-24-2006 10:49 PM
Ford F-150 Engine Swap bigjoedo Engine 3 03-30-2005 01:24 PM
460 ci ford engine help shootingstar General Rodding Tech 4 09-19-2003 09:49 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
