Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - unknown manual steering box
Old 05-10-2008, 08:28 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Saginaw would fit w/ the Chevy van theory. IF it is, should be able to track down an arm or a lead here. A lot of those splined shafts are the same (they only made a few sizes). Do you have any friends building cars who could lend you a Corvair, Vega, other, arm to try in it? What is the diameter and spline count? If you post that, I'm sure there are folks here who wold rush out to the shop and see if their arm would fit your gear.
