the unknown noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2007, 01:18 PM
the unknown noise
my 400 small block make a strange when driving down the road when i go to accelerate. it's not a knock but more of a chain dragging noise it sounds like it is coming from under the valve cover. the noise only happens when driving not when it's in park. it has plenty of oil it just sounds like somethings loose. if anyone has any info let me know.
Old 04-16-2007, 01:27 PM
Bench racer
Is this something that just started or has it always done this? Sounds like detonation, which is BAD!
check your rocker arms to see if any are loose. if they are you may wanna look at a lifter to see if its whiped a loab off the cam. but I would just try to see if one is loose. Id try to re-adjust it if it is first. if it starts doin it again look to see if the stud is coming out of the head. It happens sometimes especially on performance engines with press-in studs.
Old 04-16-2007, 01:31 PM
it's been like that for a while.someone told me it was spark knock so i adusted the timing and that didn't seem to help.
Old 04-16-2007, 01:49 PM
Bench racer
IF it's detonation or "spark knock" it will destroy the engine!
What is your timming set at and what are the specifics of the car and engine. Compression, heads, cam, intake, transmission, weight, the more info the better.
Also what changes, if any, were made right before it started doing this (new carb, cam, ANYTHING)
Old 04-16-2007, 06:46 PM
T-bucket23's Avatar
Wiki Edits: 26
Heat Riser valve ??
Old 04-17-2007, 03:50 PM
i don't know what the timing is set at. i turned it this morning and the noise whent away. i had a timing gun one time and i thought i knew how to use it but i guess i was wrong. the motor is a 1973 400 bored 0.60 over 4 bolt main, flat top pistons, edelbrock performer rpm intake, edelbrock carb 600cfm. lunati high performance cam. i don't know the specs of any of it because it was all in the car when i bought it. some days it runs good some days it run like crap. another question i have is when driving uphills it seems like the carb is bogging out what would be the cause of that? i haven't made any changes to the car other then changing spark plugs and stuff like that
Old 04-18-2007, 07:34 AM
if its bogging and making a rocking and jaring sound and it sounds like a chain is ratteling under the hood you had better check the timing. if you have a timing light hook your positive and negative to the battery and your plug wire leed to the #1 plug wire and see what it is set on. I would say its too high so try backing it down to see if you can ever see the mark. also try to keep your Idle RPMs around 650/850 rpm. anymore and mechanical advance will kick in.You will have to adjust the idle on the carb to get it to where it needs to be each time you adjust it. probably even the A/F mixture screws.
Either that or the carb is way too lean, and needs to be jetted. but I would go with timing 1st I would say to get you running set it anywhere between 10-14 degrees at idle. after that you will just have to try different settings to see which does the best. you dont really want much more at idle because It may kick back and tear your starter to pieces.
let us know what your base timing is.
hope I was some help
ford toploader noise mustang302 Transmission - Rearend 43 11-20-2006 01:24 AM
Help track down a weird noise curtis73 General Rodding Tech 10 05-01-2006 11:38 PM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 08:17 PM
Knocking noise, HELP! Please!! fireforsin Engine 4 01-04-2004 11:31 AM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
