unknown primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 06:02 PM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
unknown primer
Current project is coated with primer of unknown lineage. It was stripped to bare metal before being primed. I've been told it's etch primer. It's the weird olive greenish stuff most have probably seen. The car sat outside uncovered for several months.
The time has come to start body work.
My question is. Should I strip this primer off, starting over with bare metal?
or
Re coat with epoxy primer?
or????
suggestions?
Do you need additional information?
Thanks
Duane
Old 08-04-2008, 07:19 PM
Wiki Edits: 31
sounds like an etch primer, but has sat outside.. strip it back down and recoat with epoxy
Old 08-05-2008, 04:46 AM
adtkart@aol.com
I personally like to start a project with bare metal, where I know everything that is on top of the metal. The color of the primer is no indication of what it really is. Primers can be any color you want. Can't you check with the previous owner to find out what it is?
If you can't identify it, atleast you don't have that far to go to be back to bare metal.
Aaron
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 01:31 PM
PPG K36 primer w/ purple gun BIGSKY Body - Exterior 16 11-20-2006 12:12 PM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 09:23 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 01:28 AM
