unloading leaf spring for shackle bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 09:05 PM
its not my fault
hello im trying to unload my rear leaf springs. my rear shackle bushings are shot and am replacing them with polys. but how do i keep the thing from crashing down? can i hold the spring and shackle in place with a jack at the pumpkin? or do i have to put it on the spring in the rear by the shackle mount? does the vehicle have to be off the ground?
Old 05-12-2005, 09:08 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Just jack up the vehicle till the weight is off the spring and you should be good to go
Old 05-12-2005, 09:37 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
springs
Jack up car until wheels are off the ground. Set frame on jackstands. Place trolley jack under the pumpkin.
Old 05-12-2005, 10:22 PM
its not my fault
its pretty messed up. i got the spring unloaded. the nuts and plate off the shackle, but the bushings are not gonna come out. theyre all just cracking apart. the stud side wont release. so the leaf stayes connected. any trricks?
Old 05-13-2005, 04:56 AM
astroracer's Avatar
Hot wrench... Torch 'em out.
Old 05-13-2005, 08:20 PM
its not my fault
will a propane or map torch work?
Old 05-17-2005, 10:18 AM
shackles
The propane torch is not going to be hot enough. You can try to burn the bushing out by lighting the rubber on fire. Not sure if your bushings ares leeved or not, if so then the sleeve can be driven out with a big hammer and punch combo. Try to find a frind with a torch, will work much better.
Rear Leaf spring kits greywulf Suspension - Brakes - Steering 2 03-06-2005 02:24 PM
Who makes a 52" x 1.75" leaf spring? jpd37 Suspension - Brakes - Steering 5 10-14-2004 12:59 PM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 08:17 AM
68 Firebird Leaf spring Selection 68firechicken Suspension - Brakes - Steering 2 10-09-2003 01:01 AM
Leaf Spring Pads, are they really needed? OilPatch197 Suspension - Brakes - Steering 1 04-13-2003 10:42 PM
