Unseizing!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2003, 05:27 PM
Post Unseizing!!
The 365 in my '57cady is seized and I was wondering what was the best way to go about getting it running again? I've heard that you drain the oil and pull the plugs and fill'er right up with something penetrating such as diesel, WD-40, or a even a coal oil/tranny fluid mixture and just let it sit. But what's the best way? The fastest? The cheapest? Anybody have any experience unseizing engines, what's worked for you? Is it necessary to pull the engine?
Any help will be greatly appreciated! Thanks in advance.
Old 04-18-2003, 06:04 PM
New Member
Post
ive heard marvel mystery oil helps? take plugs out and put some in each to cover pistons.
Old 04-20-2003, 05:30 AM
mikeweyman's Avatar
Last journal entry: 2 years later
Post
all i ever heard working was stove oil(higher quality than diesel) fill er up to the oil cap. pull the plugs and fill them up . let it sit a few days , then try turning the crank with the power handle.try both ways every other day, i've seen it take 2 weeks, but it works. mikey
"BE ALERT" the world needs more lerts
