Unsettled Oil Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2012, 12:47 PM
chevy3600's Avatar
http://community.webshots.com/
I have a 51 Chevy pickup with a new GM 350 crate with only 235 miles on it, a 700R4 tranny. When I start it and run it at about 1500 rpm the oil gauge (new Classic) will bounce as much as 45 lbs. I hold it at 2000 rpm and the pressure sits at about 90 lbs. When I drop it to 1500 rpm the pressure drops to 75 lbs. At that point it will vacillate between 65 and 90. Sometimes the movement is erratic and sometimes it moves around slowly.
I have air but this is when nothing is on. I worry there is something wrong with the oil pump.
Old 08-30-2012, 01:06 PM
It's most likely just a bad guage but you'd better find out for sure before you drive it anymore.
Old 08-30-2012, 01:38 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
My Jeep (RV toad) had erratic pressure indicated, I bought a cheapo Autozone mechanical gauge to test, and it was a bad sending unit. Cheap insurance to verify it though.
Semper Fi
Old 08-30-2012, 01:51 PM
bigblockragtop's Avatar
Is it a mechanical gauge if not you might want to just replace it with one.
Old 08-31-2012, 03:45 PM
chevy3600's Avatar
No it's an electric Classic gauge. I think I'll hook up a mechanical like was suggested and see if it's the gauge.
Old 09-01-2012, 08:49 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on hooking up a mechanical gauge first.
Cole
gusher of oil from oil pressure sensor on sbc xzero117 Engine 4 08-22-2012 01:16 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Please help to diagnose- engine with no oil pressure. Oil pump failed? killerformula Engine 4 12-26-2006 10:25 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 10:37 PM
