unusual 10 bolt GM diffy off '75 SW... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2006, 06:18 PM
I need help here folks.A friend down here needs new gears and shafts for his '74 Camaro.It is a 10 bolt,3.07,open. Since these are rare here,I took me a while and I finally located a chassis that belonged to a '75 Chevelle SW.After struggling in the bushes for a while I realized it had huge drums and 1/2'' studs,not 7/16".Also,it seemed absurdly heavy to move.But it does have a 10 bolt cover.Then,after I got to the shop,the track measuremant was wider too! Is it some type of special 10 bolt differential? Comments please.
Old 08-14-2006, 06:48 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I think some of those chevelle wagons had a 5 on 5 bolt pattern
the 1/2 stud is the standard for a 5 on 5" dia
or--could be the rear of an Impala or equivalant
Bryan
Old 08-16-2006, 08:10 PM
You are right Bryan.5 on 5! And it is an unusual diffy.Eventhough it has a 10 bolt cover,it is bigger all around.Even the shafts have a larger diameter.I wonder if there are aftermarket parts for it...
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
gm 10 bolt gmonkey Transmission - Rearend 2 10-20-2003 08:26 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 05:16 AM
gm 10 bolt axle, bearings. hepcat Transmission - Rearend 4 09-20-2003 08:36 AM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 03:49 PM
