Unusual Project! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2003, 05:43 PM
drlindz's Avatar
Unusual Project!
Well fellow hotrodders, I need your guidance on a new project.
I have an idea for a "father-son" project.My 10 year old and I have decided to build an ATV type vehicle.Actually the plan is to build a child sized version of a Jeep or Hummer.
This would be a great learning opportunity for both of us.
This is a new idea and I have done no research or design yet.I thought that the best place to start would be here.This will be a built from scratch project and I hope that some of you will have some input on this.
The only things that I know for certain are that I want it to operate just like a full-size vehicle (not like a 4-wheeler or go-cart) and that it should have a manual shift transmission (floor-shift).Also, safety is a big concern.
The biggest decisions would be the engine, transmission, and rear.My first thoughts are to use a powered down motorcycle engine.This still leaves a big question about the transmission and rear.
I am open for suggestions and comments.Thanks!
Old 11-15-2003, 07:51 PM
Dawger's Avatar
Hey Doc
I was it the junkyard yesterday and saw a geo metro and was thinking how neet it would be to use the three cylinder and trans axle assembly for a similar project (i was thinking single seat buggy) .the unit was compact and looked like it could be adapted to a home built chassis fairly easily. You have seen the comercial with the hummer soap box derby car havent you?
Good luck with the project Dawger
Old 11-18-2003, 10:56 PM
drlindz's Avatar
Dawger, I am not to sure about the metro drive-train.
Although,You have led me to look into using the drive-train from a VW Beetle.It seems that that would be the easiest way to go.
BTW,Yes that commercial did inspire this project! LOL
Old 11-19-2003, 01:46 AM
Maybe you could use a shortened VW floorpan like a dune buggy uses, & build a body for it. Here's a kit for a full-length VW pan:
www.wombatcar.com
http://www.kitcar.com/hummbug.html#wombat
Old 11-19-2003, 01:03 PM
drlindz's Avatar
Now you have got my wheels turning!
I could get a "bombed-out" VW and chop the floorpan, shorten the axles, and modify the front suspension!
Add a hand-crafted body with a full roll-cage and my son will be the envy of all his friends!
Thanks for the input.
BTW: I just realized that we are neighbors,jimfulco!
Old 11-19-2003, 03:46 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
This sounds cool. Of course you know we'll require pics of this project as it evovles.
Old 10-25-2004, 10:07 AM
unusual project
I would think you want 4WD. I have built ATV utility vehicles from a Geo Tracker. I used the existing chassis and drive train, 80 HP, auto or 5 speed, 4WD, FI, instruments, etc.
Picture attahed.
