unusual swerving - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 03:01 PM
unusual swerving
ive noticed on my 1972 Nova that when i reach a certain speed limit, like around 50 or 60, my car starts to swerve alot. I think its just a loose steering column but i hope its not anything worse. any help would be appreciated. thanx
Old 02-09-2006, 08:24 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Try jacking the front end up, set jack stands under the frame on each side and then try to "jiggle" each of the front wheels. Top to bottom, side to side, movement should be nill if all is well. Just a rough guess, but I'd bet it's the center link, the pitman arm, or a ball joint going south. Front suspension stuff is nothing to horse around with. Get it checked out as quickly as possible. Most local shops to me wouldn't even charge to take a look at it.
In a while, Chet.
Old 02-12-2006, 11:10 PM
Also, check out the sub-frame bushings, the big rubber ones where the sub-frame bolts to the body. The ones on my '72 Nova were almost completely gone, and a new set made it drive like a totally different car.
Old 02-19-2006, 03:13 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
In a while, Chet.
Supporting the car under the frame lets the suspension droop. If you get any looseness there it is very very dangerous. Checking it that way usually masks any wear since the suspension parts are at a different angle than normal. The ball joints could be ready to fall apart and you would not know it.
The best way is to put a floor jack under the lower a-frame as close to the tire as possible and raise the tire off the floor so that the suspension is a normal ride height to determine how much wear there is on all front end and steering parts.
Old 02-20-2006, 05:56 PM
schnitz's Avatar
Wiki Edits: 54
OOPs, I stand corrected. I meant to say under the A arms, but goofed and typed under the frame. Good catch xntrik. Thanks.
In a while, Chet.
Unusual rear end on an old Pontiac jimfulco Transmission - Rearend 3 01-14-2006 03:37 AM
Unusual rear end... ChevApache59 Transmission - Rearend 13 12-10-2005 12:09 PM
unusual posi noise novadan Transmission - Rearend 2 04-15-2005 06:45 PM
Unusual Project! drlindz General Rodding Tech 6 10-25-2004 10:07 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
