Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it Unwise to install New Lifters without REPLACING the OLD cam?
Old 07-11-2010, 04:17 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
If they are flat tappet. Clean your present lifters. Do not mix them up. Return to original holes if they pass wear inspection. Otherwise replace cam and lifters.
With the modern oils, you will destroy the assembly, if you put new lifters on an old cam
If the lifters are roller. Inspect the camshaft for wear pattern. If cam has no pits or bad spots. Install new lifters and re assemble..
