Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it Unwise to install New Lifters without REPLACING the OLD cam?
Old 07-12-2010, 08:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by icsmannn
I have Lifter noise in a 2001 Firebird, 5 speed, 3.8L or 3800 V6. There's a lot of sludge on top of the rocker arms; therefore, I'm planning on cleaning the engine with a heavy "oil cleaner" then draining oil and reassembling al. If I need to change out lifters, will the NEW lifters damage or rapidly wear down the lobes on the original Camshaft? Thanks!
Icsmannn
Only because your engine has roller lifters (from '86-up, IIRC) is it acceptable to replace the old lifters w/new- like BOBCRMAN said already.
You do need to check the rocker arms for wear- especially on the noisy valves. The noise could be from the lifter, rocker, worn or bent pushrod or even from low oil pressure so check this over carefully before you put new lifters in it- it might not need them and they might not fix the noise.
