Is it Unwise to install New Lifters without REPLACING the OLD cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 03:53 PM
icsmannn's Avatar
I have Lifter noise in a 2001 Firebird, 5 speed, 3.8L or 3800 V6. There's a lot of sludge on top of the rocker arms; therefore, I'm planning on cleaning the engine with a heavy "oil cleaner" then draining oil and reassembling al. If I need to change out lifters, will the NEW lifters damage or rapidly wear down the lobes on the original Camshaft? Thanks!
Icsmannn
Old 07-11-2010, 04:17 PM
BOBCRMAN@aol.com's Avatar
If they are flat tappet. Clean your present lifters. Do not mix them up. Return to original holes if they pass wear inspection. Otherwise replace cam and lifters.
With the modern oils, you will destroy the assembly, if you put new lifters on an old cam
If the lifters are roller. Inspect the camshaft for wear pattern. If cam has no pits or bad spots. Install new lifters and re assemble..
Old 07-11-2010, 06:00 PM
best oil cleaner i use auto trans fluid , one qt and 4qt oil ,can you grind the rocker stand to remove gap , or try new push rods .
Old 07-11-2010, 08:15 PM
icsmannn's Avatar
Thanks
Hey Guys,
Thanks for the advice!
Old 07-12-2010, 08:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Icsmannn
Only because your engine has roller lifters (from '86-up, IIRC) is it acceptable to replace the old lifters w/new- like BOBCRMAN said already.
You do need to check the rocker arms for wear- especially on the noisy valves. The noise could be from the lifter, rocker, worn or bent pushrod or even from low oil pressure so check this over carefully before you put new lifters in it- it might not need them and they might not fix the noise.
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 03:46 PM
Howards Cams Greg T Engine 21 10-04-2009 12:28 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
solid cam and hydrolic lifters? onecoomofo Engine 4 03-29-2004 09:24 AM
replacing lifters and cam general Engine 1 09-01-2002 07:23 PM
