Unwrapping 34 Ford, cont... fenders. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 08:12 PM
Mitchman's Avatar
Grand Master of the Universe
'34 Ford coupe from Outlaw Performance.
The chassis and body came 8 days ago. The running boards, rear fenders, tank cover are just about ready for paint prep. The hood top is in it's proper place and cardboard stand-ins are in place for the side panels. I have them but they weight too much for tape and I don't want to clamp them, they're steel. The inner fenders have been trimmed for IFS clearance and set for hood panel fit.
The front fenders are just resting in place to make me feel good.
A stumbling block has arisen: The radiator needs to slide about 2." to the rear but can't. The pipes on the P/S unit are in the way. I may have to make new ones routed in a different direction.
Name:	tank cover fitted.jpg
ID:	74294   Click image for larger version
Name:	Front end first fit.jpg
Old 05-25-2013, 09:03 PM
sedanbob's Avatar
Can you lay the radiator back? Mine angles back - from the picture yours looks more vertical.
Old 05-26-2013, 05:49 AM
Mitchman's Avatar
Sedan,
Laying it back helps at the top (for now the rad's just in place to hold the hood up)... at the bottom I need a bit more space. I think if I can get the rad to move back about an inch at the bottom I'll make it. The pipes that are in the way are just plumbing. I haven't taken one off to check but if it's a flaired fitting, it's a one hour fix. I may be able to shim up about .5" also.
If I could just relocate the rad's left bracket it'd be a snap, but the bottom tank is the problem. I wasn't counting on this.
Name:	Rad - PS 1.jpg
ID:	74299   Click image for larger version
Name:	Rad - PS 2.jpg
Old 05-26-2013, 08:51 AM
sedanbob's Avatar
Yeah, it's a little crowded there - that happens a lot when you drop a v8 in a '33/'34, especially with A/C and power steering. My sedan uses a rear-steer Omni rack behind the crossmember, which helped a little. A little plumbing should give you the room you need. Keep us posted as you build.
Old 05-26-2013, 10:18 AM
Couldn't the line be routed over the top instead of straight down like that to allow for the clearance needed? They don't have to have that exact shape, they only need to go where they need to go, run it up over the top would work wouldn't it?
Old 05-26-2013, 11:26 AM
Mitchman's Avatar
Yep. It's just plumbing - easy if I can reproduce the fittings. A basic flair would be simple enough.
I'm also eyeing up the P/S pump vs steering shafts. Haven't placed the engine yet. If P/S is more trouble than it's worth, it'll go on the shelf. It is just a hot rod after all.
Chevy 383 Roller Build (cont.....) ChevroletSS Engine 99 05-23-2013 07:56 PM
54 ford fenders?? brian0605 Body - Exterior 5 06-21-2007 01:55 PM
Fuel pumps issues....cont/new 70bird Engine 3 08-28-2006 11:10 AM
ford fenders startrek Body - Exterior 0 10-26-2005 03:44 PM
'39 Ford Fenders mur39 Introduce Yourself 1 09-02-2004 11:36 AM
