Up grading brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 05:14 PM
Oldskool88's Avatar
Last journal entry: Hotrod buick
Up grading brakes
Hey hey hey guys looking at turning my 65 buick lesabre 400 in to a hotrod, looking at up grading the brakes, but woking on a budget, 1000 bucks and still need to do a lot of sheet metel work. but need front and rear brakes. any ideals on the brakes.
Old 02-17-2012, 02:20 PM
35terraplane's Avatar
Brakes
Having been in this hobby for 56 years, and watching the cost of things going up, to be honest with you $1000.00 won't get you far in this hobby. Now I have know idea what you can do yourself or what you have to do too your car, how many tools you have ETC. but just buying materials, if you are doing bodywork, that can eat up your $1000.00 pretty quick.
Bob
Old 02-17-2012, 02:58 PM
techinspector1's Avatar
Wiki Edits: 326
Oftentimes, using some ingenuity and a little work, you can make the power brakes off another, later model of the same make car work. Measure the bolt holes in the spindle and go looking through some boneyards. Even if you have to fabricate an adapter, you'll be way ahead of the game.
Old 02-17-2012, 03:03 PM
Funny thing is, your brakes on that Buick have been used to upgrade older cars for years, look at any "traditional" street rod and you will see your Buicks brakes!
I just google imaged the words Buick Drum and got 7 hundred thousand (click here) photos with the first ones I see, pages, of your Buick drums on old hot rods.
Now these old Fords would commonly use the Lincoln backing plates and shoes because they were "self energizing" where the early Fords weren't. But your Buick has the self energizing brakes too.
I know your Buick is a lot bigger and heavier, but honestly, unless you are going to be stopping from some super hot runs at the drags or you are going to be coming down off mountains with your brakes on the whole way, your original Buick brakes will do just fine.
Don't sweat it, have fun and when you get the car on the road and if you find you need more brakes, save up the dough and get them. But the better brakes aren't a MUST have to have a cool car.
By they way, don't tell me you are pulling out that Buick nailhead, please.
Old 02-17-2012, 04:31 PM
Not sure a '65 LeSabre, though a neat car, could ever be called a "hot rod"...
If you find a later model Buick you can use factory disc brakes.... find a good Buick forum.
Those old drums will bring up to $250.00.......
Old 02-17-2012, 05:24 PM
Oldskool88's Avatar
Bob
I know a 1000 bucks is not a lot the car is running, it needs a half a floor board was going to patch whats needs to be done. I was trying to restore the car and was feeling really overwelmed. So was just turning it into a hot rod but dont relly know where to start. the trunk is really bad.
Oldskool88's Avatar
No way man,
Old 02-17-2012, 05:27 PM
Oldskool88's Avatar
Plz look
If you guys don't mind take a look at my project journal, I will be posting more pics of the trunk area I have really cool ideal for it.
Old 02-17-2012, 05:42 PM
1971BB427's Avatar
The brakes on those old Buicks are really not bad. You could easily have the drums turned, get new brake shoes and swap out the master cylinder, and not have a bad braking system at all.
Took a look at your journal, and I'd concentrate on getting the car's floors and body solid first. Then just renew the brake system, not update it.
Old 02-17-2012, 06:02 PM
Oldskool88's Avatar
The one problem im having, is that my offset on my rims that i have is wrong, bought it like that, the drums are hitting the inside of the rear rims, the guy cut all the cooling fins off just to get it to fit, thats why I was thinking differnt drums, Im 24 and this is my first major project, i know how to work on them.
Old 02-17-2012, 06:44 PM
Yes the drums are expensive but that is the price to pay for cool. The guy ground the fins off. double
If you buy the wrong parts, you fix THAT, you don't do a stupid modification on a good part.
First rule in hot rodding for you, modify the WRONG part to fit, not the other way around.
But if that is all that is wrong with them, run them like that.
Old 02-17-2012, 10:50 PM
1971BB427's Avatar
Replacing the drums with the right Buick drums would be best, but as mentioned they're spendy and hard to find. Another option is to find the cast iron finned drums from another GM Pontiac or Chevy and put them on.
I'd get rid of the rims that don't clear and get either a larger diameter rim, or at least one with correct clearances. It's unfortunate that someone trashed the drums, but now the ball is in your park, and you have to decide if you're going to make it right, or live with it.
Old 02-17-2012, 11:14 PM
My the way I spoke with my brother the Buick expert and he enlightened me on the fact that your 65 Lesabre doesn't have a "Nailhead" in it. It has a 300 small block. Which is also a good motor but not a big block. I had a 65 Skylark (wish I had kept it) with a 300, and a ST300 two speed trans (Buick's version of the Powerglide) and it was a great little car. When the ST300 started slipping I put a TH350 from a 1980 Chevy Malibu (as I remember) they have a "dual pattern" bell housing that bolts to both Chevy and BOP (Buick Olds Pontiac) motors. It bolted right in and worked like a champ.
And I have to say, with that 300 in the big LeSabre I don't think you will have a big need for more brakes.
Old 02-17-2012, 11:53 PM
Here is a place to get new drums, they are $95 each. (click here)
When you get an old car like this, there is a learning curve about where to get things. Once you get into the "Community" it will blow you away that you had a hard time once to get parts. I have went to a parts store here in town to have them tell me they don't have a part. I got on line found it at the manufacturer with a part number. Called the same parts store and they had it in stock! They have for my 1959 Rambler all the brake parts IN STOCK. We are talking shoes, wheel cylinders, master cylinder, brake light switch, hoses, they had it all in stock! And that is with the weird Wagner brakes. The next year Rambler went to Bendix and those parts are even easier to get and cheaper! The same store has new Bendix wheel cylinders for a 60 Rambler for ten bucks! And this isn't a vintage parts store, we are talking the parts store that services most all the shops in town.
Do your home work, take your time and you will see that there are very few parts are really hard to get. And those that are, you just pay a few more bucks and you have them.
Old 02-18-2012, 12:37 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
These guys: http://www.scarebird.com/index.php?id=1 will get you there on a budget.
Sandpaper Grading Grit Charts 327amc Body - Exterior 2 01-17-2013 04:50 PM
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 12:09 PM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 07:52 PM
Up grading old motor chevy4x4man Engine 10 04-25-2008 01:34 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
