up-lwr control arm bushing - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2005, 02:48 PM
What`s the pro/con verse`s urthane bushing over rubber bushing`s in tubuler control arms for M-S II suspension.Thanks, Jim Cball.
Old 11-08-2005, 10:11 AM
astroracer's Avatar
Poly bushings will give a much harsher ride. If all out cornering ability is your desire go poly. If the car is a cruiser stick with the rubber.
Mark
Old 11-08-2005, 10:28 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
I have used the rubber stock bushings in my 1/2 ton pick up with a MII with lots of miles 90K+ and with 10 years time, and the darn things wore out!!! Go figure!
I recently rebuilt the truck and the front suspension bushings were all replaced with PST ( the yellow boxes ) and the ride has not changed nor is there any noise from the bushings making any squeaks. The some of the rubber ones were coated with oil which made them fail earlier, and the strut rod donuts were trashed. If this is on a heavy project I would go with the urethane ones JM $.02
Name:	photo (5) Copy (6).jpg
Old 11-08-2005, 11:31 AM
302 Z28's Avatar
The school of thought is that poly bushings will give you a harsher ride, I have not found that to be the case. Poly bushings will last longer and give you a more positive steering feel. Get the ploy bushings that are impregnated with graphite to prevent noise.
Vince
Old 11-08-2005, 01:25 PM
solidaxel's Avatar
Jim did you tell how heavy your project is?
Old 11-08-2005, 01:40 PM
solidaxel's Avatar
Jim did you us tell how heavy your project is?
Control Arm bushing replacement bonuts Suspension - Brakes - Steering 7 03-14-2005 08:06 AM
rear upper control arm bushing removal 68chevelle_ss Transmission - Rearend 18 02-06-2005 02:51 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
Ford Radius Arm Bushing Repair dmorris1200 Suspension - Brakes - Steering 0 05-03-2003 04:09 PM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
