Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Update on 36 CORD engine swap
Old 11-25-2012, 08:33 AM
Jerrycord Jerrycord is online now
Last journal entry: jerrycord's journal Cord restomod
Originally Posted by joe_padavano View Post
Does the 79 Eldo use the TH425 or the weaker TH325? The latter is derived from the TH200 and is not your best choice.
Hi Joe,you're right,the 79 Eldo uses the TH325,the TH425 was used on the earlier (1978&down) big blocks,the main reason i chose the 79 Cad. was the frame with the 350C.I. Olds eng.& TH325 trans.with all suspension is a perfect fit in the Cord bay which eliminates a ton of $$$ fabrication work.while it may not be much of a performer it'll be dependable and have enough power for highway driving. I do plan to make a few changes,like a good F.I. unit & ignition system.
Thanks for the reply Joe,warmest regards,Jerry
