Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Update on 36 CORD engine swap
Old 11-25-2012, 07:30 PM
Jerrycord Jerrycord is offline
Last journal entry: jerrycord's journal Cord restomod
Originally Posted by joe_padavano View Post
If that's the port fuel injected 350 Olds, be aware that in stock form that EFI uses an antique analog computer. There isn't even an O2 sensor. People have successfully ditched the steam-powered computer and converted to a modern digital computer using a Megasquirt or even a later factory GM ECU with a new PROM. Just get the computer controlled distributor from a 1980s Olds 307, which plugs into the digital GM ECUs with only a connector change.
And while you already have the TH325, consider swapping it for a TH325-4L. The latter is the four speed overdrive version of the TH325 and is based on the 200-4R. The TH325-4L should bolt in place of the TH325.
Hi Joe,thanks for the excellant info.I was wondering if i could convert to a 4 speed trans. I plan to do everthing you suggested!
Thanks much Joe,warmest regards,Jerry
