-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Update on 36 CORD engine swap (http://www.hotrodders.com/forum/update-36-cord-engine-swap-226434.html)
Jerrycord 11-23-2012 05:32 PM
The 36 CORD drivetrain has been sold,i've purchased a 79 Cadillac Eldorado w/58 K MI. Going thru Cad. drivetrain to avoid any "surprises" plan to begin install in Cord in late winter.
Happy Holidays to all, Jerry
123pugsy 11-23-2012 06:25 PM
Glad to hear it Jerry. :thumbup:
Keep us in the loop with lots of pics please as you go.
cobalt327 11-23-2012 08:40 PM
I hope to hear all the in's and outs of this!
Good luck and keep us posted...
Jerrycord 11-23-2012 09:18 PM
Hi Pugsy,thanks for the reply.I'll keep you all informed of progress including pics.
regards,Jerry
Jerrycord 11-23-2012 09:24 PM
Hey Cobalt,i'ts good to hear from you again.I promise to keep you informed.
Regards,Jerry
joe_padavano 11-24-2012 04:50 PM
Does the 79 Eldo use the TH425 or the weaker TH325? The latter is derived from the TH200 and is not your best choice.
Jerrycord 11-25-2012 09:33 AM
Hi Joe,you're right,the 79 Eldo uses the TH325,the TH425 was used on the earlier (1978&down) big blocks,the main reason i chose the 79 Cad. was the frame with the 350C.I. Olds eng.& TH325 trans.with all suspension is a perfect fit in the Cord bay which eliminates a ton of $$$ fabrication work.while it may not be much of a performer it'll be dependable and have enough power for highway driving. I do plan to make a few changes,like a good F.I. unit & ignition system.
Thanks for the reply Joe,warmest regards,Jerry
123pugsy 11-25-2012 10:29 AM
The tranny will be fine for cruising if its not a high torque/HP engine.
OneMoreTime 11-25-2012 11:23 AM
X2..Not every car has to have the latest and greatest high performance everything..the chosen combo should give many miles of enjoyable cruising...
Sam
Jerrycord 11-25-2012 12:27 PM
Hi again Pugsy,you're absolutly right,the Cord is being built as a cruiser not a "groundpounder"!
Thanks for the comment,regards Jerry
Jerrycord 11-25-2012 12:33 PM
Sam
Hey Sam,your back, and it's good to hear from you! Thanks for the message. Regards,Jerry
joe_padavano 11-25-2012 04:14 PM
If that's the port fuel injected 350 Olds, be aware that in stock form that EFI uses an antique analog computer. There isn't even an O2 sensor. People have successfully ditched the steam-powered computer and converted to a modern digital computer using a Megasquirt or even a later factory GM ECU with a new PROM. Just get the computer controlled distributor from a 1980s Olds 307, which plugs into the digital GM ECUs with only a connector change.
And while you already have the TH325, consider swapping it for a TH325-4L. The latter is the four speed overdrive version of the TH325 and is based on the 200-4R. The TH325-4L should bolt in place of the TH325.
Jerrycord 11-25-2012 07:30 PM
Hi Joe,thanks for the excellant info.I was wondering if i could convert to a 4 speed trans. I plan to do everthing you suggested!
Thanks much Joe,warmest regards,Jerry
AutoGear 11-29-2012 08:04 AM
Jerry;
Kudos on your purchase. Joe beat me to the punch; definitely consider the -4L.
While the SBC doesn't have the looks of the bigger motors, your decision is certainly not a new one. There are quite a few reasons the SBC is a favorite street rod engine. You can certainly make it look similar to something from the late 50s if you so desire. Do yourself a favor; lots of pictures of your progress and consider a project journal here if you haven't done so already. This is a project that deserves to be properly documented and enjoyed.
joe_padavano 11-29-2012 01:58 PM
Uh....huh?
...with the 350C.I. Olds eng....
