Update on 507" Cadillac and degreeing cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 12:17 AM
327NUT's Avatar
Just a little update on my 507" Cadillac, also a very good example as to why you should degree your cam if at all possible. I was talking to Glenn Snow at Snow Performance in St. George, Utah, they are going to do the dyno runs on this engine in a month or so. He asked me if I had degreed the cam when I installed it, I said that I didn't have the wheel or dial gauges. Well he graciously announced that he would be enroute to my house after work to perform said ritual "for a beer and gas money".....80 mile round trip mind you.
This hyd. flat tappet cam is an Erson ground for MTS...Maximum Torque Specialties, 230/235 dur., 535 lift on a 112 ICL. After we did the first degree sequence using a calculator to do the math, Glenn looked at me and said "supposed to be 112?, I got 118". I thought Oh chit, so we did it again and got the same reading. Glenn said that this is not unusual but this was a little "out there". So we advanced the crank gear and ended up with 113, did this twice to make sure.
I called Erson cams this morning and talked to one of their old time techs, he was very familiar with the MTS grind and said many variables come into play including the machinist who grinds the cam, the cam and crank gears, the timing set ( I used a Cloyes true roller and it was tight) etc. He said its always advisable to degree the cam....as I re-confirmed that to myself by example. So if you can ....by all means do it!
Anywho here's a few pics with the intake and carb just sitti'n there, need some dyno headers badly to get this thing on the pump. Might try modifying some BBC's, they are pretty close.....and yes, Glenn and his dad are great guys
ID:	64998   Click image for larger version
ID:	64999   Click image for larger version
Old 04-28-2012, 12:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good story. I tend to doubt the stack up of tolerance got you to exactly 6 degrees off like the tech from Comp was leaning towards, though. Sounds to me like the cam was made that way, either by accident or not, who knows. In any event, good thing you caught this.
The degree wheel he uses is a good one. That deal can be used to turn the engine over which is real handy, plus the additional diameter helps a lot w/accuracy.
Degreeing the cam? jtybt Engine 3 04-26-2006 07:22 AM
Degreeing A Cam (How To) Canadian Charlie Engine 1 03-10-2006 03:09 PM
cam degreeing bigpapagun Hotrodding Basics 2 01-11-2005 05:37 PM
The "wrong cam" saga update. Jmark Engine 27 01-02-2004 06:09 AM
Cam degreeing yes or no? Thacolbster Engine 4 01-28-2003 07:21 PM
