Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - update on me painting..
Old 01-06-2013, 10:14 PM
tech69 tech69 is offline
put up or shut up
scratches in your clear or under your primer? With all that primer maybe it's still shrinking. Silver metallic will show every scratch. It actually shows the most scratches so in a way you gotta treat it like a black...with black you gotta make sure your work is straight. With silver you gotta make sure any scratch under the silver is a 600 on your primer. you treat them both differently than any other color. If you have that much primer it may be shrinking and showing either your primer marks OR filler marks. Only you can tell cause pics won't show us that. Let us know what you think and we can go from there.
