Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - update on me painting..
  #17 (permalink)
Old 01-06-2013, 11:01 PM
tech69 tech69 is offline
put up or shut up
yeah, I mentioned sanding it out at the source but most shops would do what you mentioned, including mine. It's sufficient. Just gotta make sure the primer is done shrinking. Bringing it back to at least primer and reguide coating it would at least tell you for sure it's sanded out, but not tell you if it's done shrinking. The trick would be the step ups in grit, but I wouldn't recommend 320 on a silver.
