Well it seem I'll have to cut off the motor stands off the frame and move the motor & trans back about 1.5" to get clearance for a fan. I can't seem to figure out why this car has no room at the front for a fan. The way it was set up there would have been less than .75" form Rad to fan (mechanical) with an electric it would it the water pump pulley.
It's a good thing I bought this project at a good price....
On my '34 I just moved the radiator forward "into" the grille. The grill is still in the original position. The engine is located where Chassis Engineering (producer of the motor mounts) recommends it to be.
I have an insert in the shell and I can't get the Rad into the shell enough to give me room. Pusher wasn't recommended by local Rod Shop, this car is a Pro street with a narrowed back end, the body is set and can't be moved. I don't know if they may have something to do with it.
Vince,
Bruce will be going to breakfast with Bruce and the gang if you like to go then pick up Bruce's hoist and pull the motor, should be at the house by 11:00am Saturday. Also bought the Afco Rad I hope this give me a little more in the shell.
Too bad you dont have the biscut style mounts on the frame,they sell offset block mounts for them! I've seen customers that had offset mounts made for the style mount your using,but they look cobbled ain: !
I would love to have .75 inches between the fan and rad. in my 36 coupe. I would not have moved the motor back at all and I would never run an electric if I had room for a mechanical. Fans in front of the radiator are more inefficient and I would consider that as a last resort. But sounds as if you have it whipped now, assuming you have your tranny located as well and the drive shaft shortened and the pinion angle corrected.
Steve, sorry I did make it by this last weekend, we were pretty busy looking at houses. I think we looked at about 12 or 14, I lost count. We found a house on 2 acres with a 3 car garage we may make an offer on.
Looks like you made some good progress. Where did you get that snazzy engine/trans stand?
I'll be glad to keep the Cuda for you, just bring the pink slip .
Vince
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
