Update: T5 straight up shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2003, 07:42 PM
Since my original post I have come across a hydraulic bellhousing that will allow the T5 to be mounted straight up rather than canted to the left. The bellhousing is for the 84-88 Corvette 4+3 transmissions. The main trans was a BW T10 which has the same bolt pattern as the T5. I saw a used one for $165 at car-parts.com.
You should be able to use one of the Hurst straight up shifters (S10?) for the T5 and use whichever stick you'd like.
Hope that helps.
Larry.
