updating brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2012, 10:50 AM
Last journal entry: owner of heads emotionally attached
updating brakes
A couple of questions for the knowledge base! why are all the aftermarket brake boosters mount with such an extreme angle? As the booster kit that came with this project puts the master cylinder at such an angle it can't possibly be correct. I've tried looking up factory apps. that should work and yet the angle on those appears to be similar.....project "66" elky, drum/drum......thanks
Old 05-22-2012, 09:12 PM
Cape Cod Bob's Avatar
I'll assume you have a bracket that allows the booster to be mounted to a part of the frame that is at an angle to the rails?
What is your application. Firewall, under floor? Pi cs help.
Old 05-23-2012, 12:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
At least part of the MC angle is due to the nose dive/weight transfer that happens under hard braking.
Old 05-23-2012, 10:58 AM
thanks
Bob the app is a 66 el-camino so it is a firewall mount never considered that reason however the angle is very extreme [not to good at degree %] but firewall area is perpendicular where it needs to mount will try to send pic[IMG]. [/IMG]The kit appears to be street bandit
Name:	2011 misc 004.JPG
ID:	65530   Click image for larger version
Name:	2011 misc 005.JPG
? about modifying/ updating stering 49fordp/u Suspension - Brakes - Steering 7 07-21-2009 10:03 PM
updating the headlights in my elky elcaminodragster Electrical 3 01-15-2009 06:33 AM
updating a chevy vpillusion Suspension - Brakes - Steering 2 04-22-2006 05:41 PM
updating to power steering & brakes stanjr41 Suspension - Brakes - Steering 1 12-26-2003 08:43 AM
updating steering column rp Suspension - Brakes - Steering 1 05-08-2002 04:29 PM
