updating my 53 customline rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2012, 05:46 PM
was wondering if anyone could help.i have a 53 customline with original rear axle and im wanting to update/upgrade to a rear axle that has disc brakes and a better highway gear ratio.anyone know if i can use a mustang or a Lincoln rear axle or ? thanx for your help.
Old 11-11-2012, 06:56 PM
big gear head's Avatar
High Performance Rear Ends
Yes, you can use one of them as long as the total width will work with the wheels that you want to use. The bolt pattern on the axles will be different. Swapping a rear end into something with leaf springs is pretty simple.
Rear axle help frickenbored Transmission - Rearend 9 02-06-2012 04:31 PM
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 08:25 PM
rear axle ??? Gr8lite Hotrodding Basics 1 08-20-2005 06:28 PM
rear axle murfeey General Rodding Tech 1 05-21-2005 10:56 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
