Upgrade from 460le - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-18-2013, 11:22 AM
jokerZ71's Avatar
Wrench Turner
Wondering if he could use the PROM from 95 standard trans for his engine mgmt & then use the shiftmatic or other contoller the trans he chooses to go with.IIRC,the only signal from the manual trans would be the VSS.Not sure if it would be doable,but,in theory,it sounds good.LOL.
  #17 (permalink)
Old 11-18-2013, 03:12 PM
Thanks Guys for all the info, I still am a little confused but I will look for a shop that has done the conversion to a 4l80e.
  #18 (permalink)
Old 11-22-2013, 01:50 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
Don't take this wrong but you need a 2500 truck so you can pull your trailer.
"just swappin in a 4l80e" is way more than just bolting it to the back of the engine. You will need to split the transfer case and swap in a 32 spline input so your new 4l80e can bolt to the case. Not sure on the length but this could introduce the need for nodding a couple drive shafts. We haven't even got to controlling it with the computer.
You can pick up a 96-99 k2500 burb for way less $ and hassle. Then you get a BBC, the 4l80e, a full floating 14 bolt rear and the bigger brakes. Just way simpler.
The Following User Says Thank You to TexasT For This Useful Post:
Crosley (11-23-2013)
5.4l upgrade prumora1 Engine 1 04-04-2013 09:50 AM
h4 upgrade wrangler Electrical 5 10-01-2007 05:37 AM
460LE (??) Gm automatic Question schnitz Transmission - Rearend 6 05-15-2005 05:33 PM
Help with 460LE tranny in a 1995 camaro 95camaro!! Transmission - Rearend 3 05-30-2004 05:55 PM
460LE bbr273 Transmission - Rearend 2 08-05-2002 07:56 PM
