upgrade 62 chevy truck rear suspension. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2009, 01:27 PM
i am working on a 62 chevy truck. I have always disliked the suspension under these models. They just seam to squrlly. i would like to put some sort of a corvette rearend or a camaro. 4.11 or so. Not sure if it is even possible.But i want a solid stance in the rear. Is it possable to change out the rear susp. and could i put a 4.11 under it with out major mods. thanks for any info.
Old 02-04-2009, 02:47 PM
poncho62's Avatar
Wiki Edits: 5
Is this the rear suspension with the long trailing arms and coil springs?
You do realize that this suspension setup is the basis on Nascar race cars?.......a very solid setup. Probably all you need are some better bushings and a more solid panhard bar.
Old 02-05-2009, 08:13 AM
yes it is the susp. your thinking of. and no i didnt no that about the nascar.
thats good info. Thanks. in past i havnt realy messed with the suspension on any of my projcts. Mainly concentraited on the motor and tranny. but i realized that suspension means a lot in street rod also. Thanks again.
Old 02-05-2009, 09:07 AM
SSedan64's Avatar
Harley, the Truck Arm suspension is a great setup. Like stated above, nascar uses the same principle design. These guy's sell this design to retro fit into a number of cars, rods & trucks.>>>> http://www.hotrodstohell.net/
http://www.hotrodstohell.net/catalog/catalog.htm
http://www.hotrodstohell.net/truckar...karm_index.htm
Old 02-06-2009, 08:26 AM
machinist & fabricator
you dont need another suspension set up, your truck arm setup is designed to lift the rearend upon power transfer, which transfers weight to the front, just the way you want it.
take the words from a wise man ( all pontiac people are wise) replace the bushings, and pan hard.
the only downfall to this type suspension is that its not very good for air ride, due to the pinion angle changes throuout the lift.
if you seak to replace the rearend with another model, all you need to do is determine the length of the rearend (backing plate to backing plate)
if the donar rearend is a leaf spring car, cut the shackles off and
USE A ANGLE FINDER to set pinion angle at ride heighth.
if your looking for lift, do a 4 link, it minimumizes pinion angle changes..
i built my own truck arm in my 1930 olds coupe, and it handles and gets traction quite well!
good luck.
Old 02-06-2009, 10:37 AM
thanks for the info.
cab and bed mounts 62 chevy truck boatanchors Suspension - Brakes - Steering 8 07-05-2012 10:27 PM
will a volare front suspension work on a 1953 chevy truck? D351W Suspension - Brakes - Steering 4 12-05-2008 11:28 AM
50 Chevy 3/4 rear suspension mr52pickup Suspension - Brakes - Steering 1 04-23-2006 10:04 AM
Rear Splash Apron for a 1947-53 Chevy Truck bg Body - Exterior 12 01-24-2004 03:08 PM
Brake / Suspension Upgrade - 75 Chevy Pickup dwstevenson Suspension - Brakes - Steering 0 12-31-2002 07:42 AM
