Upgrade to power windows - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2006, 12:55 PM
Hi. I have a 66 Chevy Caprice with manual crank windows and want to convert to power windows. Has anybody done this on a car with curved side glass using aftermarket components? I've seen a coupla power window sites but would like to hear some first hand info. I don't want to spend the time looking for old factory stuff that may or may not work. Thanks.
Dick
Old 06-07-2006, 06:21 PM
kristkustoms's Avatar
First name...............Shawn
Dont use the kits that have a flexible shaft that just attach over the original crank shaft. I had one that went out in about a year. Cant help with suppliers for what you need though...
Old 06-07-2006, 08:30 PM
powerrodsmike's Avatar
Wiki Edits: 161
I second that what kristkustoms said don't use the adapto cable drive ones. They are crappy.
Try Specialty Power Windows in Georgia. They have some universal kits that can be installed in a car with curved glass. I think the power wonder lift will work in that application. (#pwl 2C) You may be able to get their gear drive unit to work in that application. (#2416 U) The gear drive is a little more positive as far as window stability.
Here is a linkhttp://www.spwkits.com/streetrodkits.htm
I have used their products in many cars since 1987 and have never had a problem . I use their cable drive windshield wiper kits also. The quality is excellent and all of it is made in America using GM parts where ever possible. Hope this helps, mikey
BE different....ACT normal.
Old 06-08-2006, 10:11 AM
Thanks guys, that's the kind info I'm looking for. I've been checking this site out, seem to have alot of options -- www.electric-life.com/main.asp.
Thanks
Dick
Old 06-09-2006, 04:54 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Thanks
Dick
I have a friend that has probably installed 25 of the electric life kits. Very good quality product.
Wacky Power Windows airman_turtle Electrical 12 08-16-2006 06:18 PM
power windows died Fresh469 Electrical 6 07-05-2005 08:59 AM
Power! -- No power? -- Power!!!! No Power???! Fragzem Engine 10 05-16-2005 01:30 PM
50's Chevy truckw w/ power steering ? Slickriffs Suspension - Brakes - Steering 3 10-13-2004 05:18 PM
power windows 79 t/a mrhappy66544 Electrical 1 10-07-2004 07:16 AM
