upgraded gears for V-8 saginaw 4 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 02:00 AM
Does anyone out there know where I can get an upgraded(strengthened) gears for the saginaw four speed for the V-8's. I heard on one of these threads they were available but saginaw replacement parts suppliers I've contacted on the net don't answer questions for some reason. I'd appreciate any help on this as any munci M21 or 22 you'll find here is totally dogged and real expensive in junk condition. My understanding is some saginaw replacement gears are stronger powder metal pieces,just a more modern fabrication process that delivers a better product, but, it's only heresay(on the net). I always liked the saginaw tranny's,had good luck with all I had.
Old 05-13-2013, 12:50 PM
The only Saginaw gears I know of being re-popped are the 3speed input/clusters that all the short track guys use. As far as the Muncie stuff; its very hard to compete with the junk from India. Theres no way visually to convince most guys that a quality gear made in Italy is worth 20percent over the same visually appearing gear made in India or China. All Trans in Portland (now Transtar) seems to have a consistent product for an M20 with say a 350hp SBC in a street car (not a 10second street car, a REAL street car). If you want quality Muncie gears, you have to go to a M22 or M22Wide. The reason is that the lions share of performance guys have more than 400hp and require the strength the M22 platform provides. ADDITIONALLY; the worst part of a Muncie is the flyweight aluminum/potmetal case. A person really needs to evaluate their Aluminum case before investing in a quality gearset. A worn out case eats gears.
The Following User Says Thank You to AutoGear For This Useful Post:
yankee phil (05-13-2013)
Old 06-03-2013, 02:38 AM
[QUOTE=AutoGear;1675285]The only Saginaw gears I know of being re-popped are the 3speed input/clusters that all the short track guys use.] Yankee Phil asks: Do you know the supplier of the saginaw gear clusters for the racing transmissions and can you please tell me the name and address of that company . I'd appreciate any help in this area.
Old 06-03-2013, 09:32 AM
All Trans Parts in Greenville SC
All-Trans, Inc.
134 Transit Drive
Greenville, S.C. 29607
The Manual Transmission Experts | All-Trans
1-800-922-9562 Ask for Bill; tell him Nate from Auto Gear sent you.
yankee phil (06-03-2013)
Old 06-03-2013, 01:55 PM
All-Trans, Inc.
134 Transit Drive
Thanks a lot Nate,this helps a lot and I appreciate it.
Old 06-03-2013, 02:04 PM
No worries, here to help
Saginaw trans gears Camshaft3 Transmission - Rearend 4 08-30-2012 07:18 PM
Differential gears to match Saginaw trans. Caballerokid Transmission - Rearend 7 05-06-2010 05:38 AM
Saginaw 4 speed, how much can it take? Vega446 Transmission - Rearend 2 12-14-2009 07:41 PM
Saginaw 4-speed NewOldBlue Transmission - Rearend 0 02-17-2004 12:07 PM
saginaw 3-speed ? bowtieorbust Transmission - Rearend 2 01-12-2004 08:54 PM
