Upgraded steering on a 68 Camaro
Hey all,
Just thought I'd share with you the swap I completed last night. It's a somewhat common swap, but thought I'd mention it over here in case anyone else is playing around with a First Gen Camaro.
Yesterday, I took out the stock power steering gear box, with a 3.5 turn-to-turn ratio, and replaced it with the box from a late 80's/early 90's Camaro. I was sure to select the box from the performance steering option. It has a 2.5 turn-to-turn, and dramatically reduces the floaty feeling found in older steering.
The swap was pretty straight forward.
I won't go through the install step by step unless asked, but here are a few things you need to know:
1. The 3rd gen box does not use flared fittings by default, and the 1st gen power steering lines do. A company called Lee Engineering makes adapters for these. The 3rd gen box is metric, and the 1st gen, standard threads, but they are so close that the 1st gen lines thread into the 3rd gen box without any issue. I believe the fittings were 5 bucks a piece, and the punch to install them was 5 bucks. I went up to Oreily's and picked up a Cardone #276550 reman box for about $116.
2. You'll need a new steering coupler. Most guys say that after 40 years, it's time to replace the stock one anyways. Lee sells a kit that includes the coupler and fittings for 90 bucks or so, but you can also source the coupler from GM. GM #7826542 should be the right coupler.
3. Driver side headers may need to come out or be loosened.
4. Loosen all the bolts under the dash holding the steering column in. And loosen the coupler bolt on the steering box, then pull the shaft in the car to pop the coupler off the steering box. It's easier to remove/replace the coupler after the steering box is out.
5. The Pitman arm nut is a pain in the behind. Use a puller and a big wrench. Reinstallation torque is anywhere from 140-180 ftlbs. Be sure the splines are lined up properly. If your Camaro already had power steering, the pitman arm should be fine. If you're going from manual to this power setup, you'll need the right power steering pitman arm.
6. Once done, flush the system then connect the lines. Then turn the wheel end to end to get the air bubbles out.
7. Take it out, and enjoy.
Feel free to post any questions, and I'll help as best I can. I am by no means an expert on this, but did manage to get it and have put about an hour driving time in with no issues (fingers crossed). Overall, for 200 bucks, it was definitely worth it!
Bringing history and technology together.
