Upgrading Original Bench Seats Support For My 41 Plymouth - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2012, 05:54 PM
How much will 61compression foam sink with my 210 pound butt planted in it? I am trying to figure out how thick the foam needs to be. I assume the seat backs won't compress much at all. Correct?
  #17 (permalink)
Old 02-27-2012, 11:31 PM
DanTwoLakes's Avatar
Wiki Edits: 22
61 compression should be fine if it's at least 3" thick. I'd go with 4" if I were you. No, you won't compress the foam much on the seat backs. There you could use 2" and be just fine.
  #18 (permalink)
Old 02-29-2012, 11:19 PM
Thanks, Dan. I'm beginning to get the picture. I'm not convinced that even with new springs, the seats would be comfortable on long trips.
  #19 (permalink)
Old 03-01-2012, 07:05 AM
Wiki Edits: 22
The seats will definitely be better for long trips with what you plan to do.
  #20 (permalink)
Old 03-17-2012, 08:27 AM
Dan,
I got a block of 3",4" & 5" foam from Rochford. I like the way it sets up with the 5" block as the bottom cushion and the 4" block as the seat back cushion. I have the rake adjusted to where it is very comfortable to me and my 6' 2" frame.
Here is my question. The upholsterer will add additional padding to the foam. Correct? Will this additional padding add any significant changes to my dimensions that I have dialed in? Or will that be mostly insignificant.
Thanks for your help!
  #21 (permalink)
Old 03-17-2012, 09:00 AM
Wiki Edits: 22
The upholsterer may add some dacron batting to the foam, but that should be insignificant to the end result.
  #22 (permalink)
Old 03-17-2012, 09:20 AM
That's what I thought. Thanks again!
  #23 (permalink)
Old 03-18-2012, 06:08 PM
Worked on my seat this weekend. I could not live with the springy original seats but I wanted the seats to look mostly original. With the help of DanTwoLakes, I came up with this solution.
I built a 3/4" plywood base for the bottom and two 1/2" plywood seat backs with brackets to make them mount in the original frames.
I ordered a sheet of 3", 4" and 5" firm foam to try. I ended up liking the 5" foam in the bottom and the 4" in the backs. This will fill out the frame and make the seats look good and sit good. These things are better than my sofa in my house and I have the seat and steering angle to my liking now.
I had to make an adapter that moved the seat back a couple inches and will make a block that will get the inclination like I want it.
The seat frame will still need to be blasted and painted. Then, when I'm ready, I will take it to the upholsterer and let him finish trimming the foam and do the upholstery. I'm pretty happy how this turned out, so far.
Suggestions?
ID:	64090   Click image for larger version
ID:	64091   Click image for larger version
ID:	64092   Click image for larger version
ID:	64093   Click image for larger version
  #24 (permalink)
Old 05-25-2012, 06:29 PM
Hot Rod Has Been
Nice job... my '52 Pontiac also has some pretty weird seating for some reason...way too thick of a seat cushion to be comfortable for me. I might try this when the time comes.
  #25 (permalink)
Old 05-25-2012, 07:42 PM
Wiki Edits: 22
If it makes you happy, that's all that counts.
bench seats.. jennftb Body - Exterior 5 11-17-2010 09:00 PM
65 Comet Bench Seats 65comet Interior 4 03-30-2009 10:26 AM
bench seats trifivefan Interior 3 10-19-2004 09:10 PM
Technical support for upgrading a gas guzzler vanashae Engine 0 01-16-2003 03:20 PM
Bench Seats gasbo44 Interior 0 11-22-2001 06:51 PM
