upgrading running gear on f100 1963 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 02:20 PM
can anybody give me info on what will fit to this truck,to improve, brakes, steering,surpension. somebody said a camaro complete front sub frame would work.
Old 01-18-2006, 03:41 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Front end clips
By the time you get done with buying the clip and all the ball joints tie rod ends etc. etc. and so on to rebuild it and make it good it will cost as much or more than buying a good aftermarket crossmember..
I would suggest www.jimmeyerracing.com to source a cross member to fit that truck..those chassis are plenty strong so there is not a real need to do any boxing..
Only thing to be aware of is that the Ford pickups use a 5x51/2 bolt pattern on the wheels so there are not a lot of wheel options..
Might wish to change the rear bolt pattern so both ends match if you do this..
http://www.jimmeyerracing.com/pu5.html for the exact piece..
OMT
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
Rear-end Setup opinions RObs71Nova Transmission - Rearend 6 03-11-2005 05:54 PM
Erson Gear Drive Woes blndweasel Engine 9 07-14-2004 09:53 AM
flywheel ring gear somethin4nothin Engine 6 09-25-2003 08:36 AM
3.8 litre 1993 taurus won't keep running when in gear steve norman Engine 6 12-01-2002 07:37 PM
