upgrading steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2008, 01:19 AM
I've got an '81 k-5 with the old style (like 70's) switches on the dash and only the turn signal switch on the column, but i put in a late 80's column with the lever to contral trun signals, wipers, and brights.
so I'm trying to find out what other people have done in this situation, on how to wire everything over to the new column?
any info or tips on the electrical would be appreciated
thanks, Mike
Old 06-22-2008, 09:32 AM
Not easy
This will not be an easy job. I recommend you get wiring diagrams for each car. Leave the connector in place at the bottom of the new column and buy the other side of that connector to use to run your wires to.
See if you can get that connector from a dealer of a higher end auto parts store such as NAPA.
From there it's following which wire goes where on each diagram and running the appropriate wire to the new connector. Hopefully the new connector will come with the pins that you can remove and install the wires to and I highly recommend soldering.
Steve
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
Steering column switch 82 Dodge 150 Bryan59EC Electrical 6 07-05-2008 08:07 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 01:08 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
