Upgrading T-400 stall converter - Do I need trans cooler
So i am upgrading my TH400 stall converter from basically stock to a 2800. Do I need to use a seperate trans cooler? If I do, is best to use the current the cooler in the radiator and just add the new trans cooler in line after the radiator or run it completely seperate?
I am using this as a street crusier and will most likely not see the track. Just for having fun with my buddies and taking mama for weekend drives, car shows and ice cream. Last what type of cooler is best or recomended? |
You may not NEED one...but it's cheap insurance in case you do stop and go traffic on a really hot day.
Any increase in Stall is gonna increase heat. I say add an Auxillary cooler.
If you live & drive in cold weather get a Cooler that's self-regulating like the TruCool brand. transmissioncoolers.us: Tru-cool thin coolers |
OK. Great. So now to add this I put this is tne return line route to the trans. Correct?
If I mount this in front of the radiator will this affect my engine cooling or will the air flow simply cool both? Another question. By adding this in line with the radiator does this help take heat off the radiator or because it is in line after the radiator is doesn't? I am not having any engine heat issues but am just curious. |
| can I use a 700r4 torque converter in a turbo 400 trans | kevinneal | Transmission - Rearend | 4 | 06-12-2011 06:13 AM |
| Second Trans Cooler if Using Stall Converter? | beertracker | Transmission - Rearend | 19 | 11-29-2010 11:56 PM |
| Trans Brake vs. Stall Converter | timcourtney | Transmission - Rearend | 9 | 06-29-2010 01:45 PM |
| Stall Vs 400 torque converter | mahoho | Transmission - Rearend | 5 | 09-14-2009 06:51 PM |
| t-350 trans with stall speed converter problems | kwopper07 | Transmission - Rearend | 1 | 12-29-2007 07:52 AM |
