upgrading valve springs and stem seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2009, 05:27 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
i need to change my valve stem seals but i dont want the o ring style i want the umbrella style. i would also like to upgrade my valve springs. they are 350 heads from a 69 camaro. i believe they are single springs with the damper spring.
i have a 268h cam but i never upgraded the spring as it is recommended so i would like to now since i have to replace the stem seals.
i want the umbrella seals because ive heard lots are read lots more that they are the best seal. but i dont know which ones to get. some say machine work required others say its not needed.
as far as valve springs. should i buy single or dual springs. what about a damper? spring rate? bind hight? etc. im not sure what to look for.
what other information do i need to list to help you tell me what i should look for?
Old 08-09-2009, 05:35 PM
302 Z28's Avatar
I have installed umbrella seals that came in a Ford gasket set on a SBC with no problems. They just slip over the valve guide boss with nothing to hold them down, but they do a much better job than the OEM "O" ring type. The Perfect Circle type bonnet seals do require machining of the valve guide boss. They have a crimped wire retainer that goes over a groove cut in the boss.
Vince
Old 08-09-2009, 06:41 PM
something like this???
http://www.summitracing.com/parts/CCA-504-16/
they just push on and sit inside the spring. but then what time of springs would i use with those?
Old 08-09-2009, 07:13 PM
justold's Avatar
I don't remember the part number , but the app is 1957 Cadillac they fit well and they don't interfere with the springs . As far as the springs I can't help you , contact the cam mfg. .
Old 08-09-2009, 07:17 PM
ericnova72's Avatar
More for Less Racer
That type is what 302 is referring to, but that part # is for 3/8" stems and SBC is(99.8% time) 11/32". The correct size will fit inside a stock diameter spring.
Old 08-09-2009, 07:42 PM
ok but that style would work for me (just the 11/32")??? and be able to fit under most any spring setup???
here are some pics of the springs that are on my engine now. . . hope they help all of you tell me what i have and what i might be able to get. there are so many options on what kinds of springs to get im lost on what would be good for my engine
Name:	Engine removal 020.jpg
ID:	39882   Click image for larger version
Name:	Engine removal 052.jpg
Old 08-09-2009, 07:51 PM
ericnova72's Avatar
More for Less Racer
Yes, the seals will fit, your springs are the stock diameter of 1.250", you just need to pick a spring that matches the spring poundage requirements of the cam in that 1.250" diameter.
Old 08-09-2009, 08:00 PM
so 1.250 outside diameter 1 2 or 3 springs? what about a damper? what exactly is a damper anyway???
Old 08-09-2009, 08:15 PM
302 Z28's Avatar
I would toss the dampers, never had em on any engine I have ever built and ran.
Vince
Old 08-09-2009, 08:19 PM
Vince
what exatly is a damper??? what is its job???
Old 08-09-2009, 08:24 PM
ericnova72's Avatar
More for Less Racer
Can't pick a spring out of thin air, it has to match what the cam needs for pressure, and how much pressure it needs decides how many sets of coils it has.
The damper is the flatwire wound piece thar sorta looks like a spring inside your current spring(which is called a single spring w/damper, by the way). Damper serves the same purpose as putting you finger up against a vibrating guitar string to kill the harmonic vibration.
Old 08-09-2009, 08:39 PM
i understand that you cant tell me to buy this one or that one. i was asking what i should look for and i got my answer.
i need it to match the cam. i found the papers for my cam and it says to buy these springs http://www.summitracing.com/parts/CCA-981-16/
and i will use these seals http://www.summitracing.com/parts/CCA-502-16/
thank you for all your help everyone i appreciate it greatly
Old 08-09-2009, 08:49 PM
one more question. . .
do i have to buy the retainers that go with those springs or can i use the ones i currently have???
Old 08-09-2009, 09:00 PM
ericnova72's Avatar
More for Less Racer
You can use the stock retainers just fine. I might suggest replacing the locks just for insurance, they're what holds everything together. Nothing fancy, new stock replacements are enough.
Old 08-09-2009, 09:05 PM
ok cool.
i just read a little bit on the seals being crushed due to a lift higher then .420 is that true??? because my cam is .454 lift
is there anything else i should replace just to be on the safe side??? push rods? rocker arms?
Valve Stem Seals mightycarlo10 Engine 5 05-16-2009 08:38 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Valve Stem Seals? Grant209 Engine 19 03-02-2004 03:09 PM
valve stem seals HQ Pete Engine 2 04-02-2002 12:04 AM
